So you have a dead device and you're thinking of sending it to iPad Rehab to get back those vacation pictures or important business contacts. Let's go over our data recovery policies to make sure that we are all on the same page regarding the fine print for our service. Our goal is to be as transparent as possible. If you still have questions--give us a call at 585 397 4174 or send us a message at info@ipadrehab.com
Every recovery starts with a formal quote request that captures information from you. Click "Get Started" at the top of this page. This form will have you enter your contact information, mailing address, and tell us about your device. The information you enter here will be transformed into a printable sheet that you will receive when we reply with your quote and instructions. You'll need to send that sheet with your device so that we can match your device to your ticket at intake. Anything you tell us about the history of your device and problem here on this form will stay with your device and help the technician. Think of the technician as your phone's physician--be as detailed as you can. Little clues from the history can sometimes make or break a difficult recovery. Once you've submitted the form, our business manager will make sure that your phone is a good candidate, and she will respond by email WITHIN 24 HOURS with your formal estimate and printable info sheet. If it has been more than 24 hours, something is wrong. Sometimes emails go to spam, or there was a typo in your captured email address, or something happened. If you don't hear back from us within 24 hours, give us a call 585 397 4174.
Standard data: $500 - $1000 *Applies to devices that have NOT had a prior microsoldering attempt.
iPhone 3g, 4, 5, SE 2016, 6 series, and iPads $500
iPhone 7,8,SE 2020,and X series $700
iPhone SE 2022, 11, 12, 13, 14 series $800
iPhone 15 series $1000
iPhone Specialty data: $700 - $1200
All standard iPhones that have prior microsoldering repair attempts.
**Android data: **
UNENCRYPTED models running OS 5 and below - $500
Models running OS 6 and up - $800 - $2000
CPU transfer: $1000
This unique service is for logic boards that have catastrophic damage that spared the data containing big chips (lawnmower or bent in half in car door) or for logic boards that are not repairable using standard methods but the CPU shows some electrical signs of life. If standard methods are unsuccessful we may offer this service to provide a path for data acquisition by transferring the CPU, SDRAM, NAND and EEPROM to a receiver board of the same model. We may ask you to provide the working receiver board for some models.
We expect that you may open your device to 'see if it's something easy' like a bad battery, dock connector or screen--those things do not complicate our logic board repair process. However, when someone else tries to fix a non-functional logic board by microsoldering--that erases our clues and introduces variables that makes our job much more difficult, or impossible. Devices that have had prior microsoldering repair attempts (i.e. the soldered on shields have been removed) will be requoted as specialty data. Some prior repair attempts may not qualify for our no data no fee guarantee. In those cases we will assess a minimum non-refundable labor charge to invest any time at all into a board that others shops have already deemed unrecoverable.
We guarantee that we will be able to get a PATH to YOUR DATA, or no charge for the time and chip cost that we invest in your logic board. We do not guarantee that the data that you seek will be on the device, or that your passcode is correct. We will consider the recovery effort a success for standard/specialty/cpu swap as long as the device turns on in our hands and accepts passcode--at least temporarily. We will provide a screenshot of your lock screen to prove that the device was in a ready to recover state if necessary. We will bill for successful data recovery if we can get a PATH to data, even if you don't have the correct passcode. If the wrong passcode is entered too many times, a recoverable device can become permanently disabled, at which point there is no feasible way to recover the data. If you are unable to provide the correct passcode and the device becomes disabled, or if the device was only able to boot once and you did not give us the correct passcode, that does not negate the work that we put into bring the device back to a recoverable state with a path to data. We can not qualify a device as 'not recoverable' under no data no fee because of wrong passcode. For chip-off android devices we will qualify them as not recoverable if the chip can not be read. If our chip reader can read the chip, then it is considered a successful path to data. Forensic analysis and parsing of data is not part of our data recovery service.
It is tempting to send a phone that you really want the data from to us on a repair quote instead of data recovery. Wouldn't it be great to get the data, AND get a warrantied working phone, all for a lower price! Our advice is that if you are really wanting data, then send it on a data recovery quote, and here's why:
We treat data recovery cases differently than repair cases. On dead devices sent for repair (not recovery), our goal is efficiency. We are looking for common repairable faults that can be fixed to create a robust working device that we can warranty. Under our no fix no fee repair model, we can not put extraordinary time into open-ended problems. We will use software restore (which erases data) to eliminate all software variables on dead devices that are just here for repair. Not every device will be restored, but if we need to restore to pursue fixing the device on a repair quote it is required, i.e., you can't opt out without incurring a cancelled repair fee. We will not work on any device for repair that we can't warranty, so devices with multiple issues will be declared No Fix. We will not work on any liquid damaged device on a repair quote, we only address liquid damaged devices on a data recovery quote. Devices that are sent in for data recovery will go straight to our master technicians, while devices on a repair quote will be serviced by junior technicians. On the other hand, on a data recovery quote we will leave no stone unturned and always take measures to preserve your data. While we don't guarantee the long term function of our data phones, if we can send you back a working phone then we will. If you are really wanting data, send the device on a data recovery quote for the best chance for your data.
When we go to the doctor, we need to take off our underwear. When you send your phone for data recovery, you need to send the passcode before we can begin work on your device. We can help you if you aren't exactly sure, but ultimately it is your responsibility to provide the correct passcode. We will bill for a successful path to data if we can get the device to boot even just once where we could have retrieved the data if you had sent the correct passcode. If you do not know or provide the passcode, that does not invalidate our efforts to bring the device back to a point where it could be recovered. We consider a one time path to data = billable successful data recovery.
There is absolutely no path to data for any device that has full disk encryption by default (most modern smartphones) without the passcode or use of costly forensic software. Unless you are sending an older Android phone, we can't just read the data from the flash memory chip on the logic board, here's why. In order to recover your data, we have to cure hardware problems and get your phone to boot again. This means surgery! We will operate on your phone under the microscope replacing corroded chips, finding and clearing short circuits, and sometimes applying creative workarounds with Frankenstein wires to inject voltages in elaborate methods of getting your phone to boot. For some devices, we may only be able to get it to boot ONE TIME. Once that phone comes up, we need to immediately enter the passcode to decrypt the data and pass a trust handshake to extract your files from the device safely to a computer. There is nothing worse than working for weeks on a phone just to get it to boot once and find that someone put "NONE" on the passcode sheet because they were uncomfortable giving us their passcode. Don't be that guy!
We will bill for successful data recovery if we can get a PATH to data, even if you don't have the correct passcode. If the wrong passcode is entered too many times, a recoverable device can become permanently disabled, at which point there is no feasible way to recover the data. If you are unable to provide the correct passcode and the device becomes disabled, or if the device was only able to boot once and you did not give us the correct passcode, that does not negate the work that we put into bring the device back to a recoverable state with a path to data. We can not qualify a device as 'not recoverable' under no data no fee because of wrong passcode. If you do not know your passcode there may be forensic software options we can offer. Forensic recovery is possible on some devices and pricing varies.
*** There many be Forensic options available. Please contact us directly to discuss what may or may not be available at 585-397-4174. ***
Passcode Policies:
I know the passcode, but I don't want to tell you: If we work on the device and get it to boot even just once and you haven't provided correct passcode, you will be invoiced for successful recovery.
I Really Don't Know the Passcode. Don't send the device.
I think I know, but I'm not SURE About Passcode. We understand that sometimes you might not be sure about the correct passcode, that's okay.
If your submitted passcode doesn't work, then we will confirm that this is your device and show you that we have a path to data with a picture of your lockscreen. Once your invoice is paid, the extraction team will work with you to try three additional possible passcodes. If none of those work, then we will work with you on a case by case basis to send the device back to you in a state where you can continue to try passcodes. Sometimes muscle memory and seeing the lock screen will help you remember the passcode on a device that hasn't been working for years. We may need you to purchase parts or a donor device in order to be able to send the phone back to you in a condition where you can attempt to unlock the device. We can't guarantee that a phone that we can boot in house will be able to boot once it leaves our facility.
Once you have received your estimate from us, then simply follow the mailing instructions to send the device to our facility. Devices that show up without our pre-filled printable estimate are a hardship and there is no guarantee that we will be able to process your device at all.
Who pays for shipping?
You do. There is no such thing as "free" shipping, and we choose to have customers choose and pay shipping so that we can keep our No Data No Fee blanket policy---if we can't recover the device, no matter how many hours of time and replacement chip costs went into your case--- we can recycle it for you and you owe us nothing. We recommend shipping your device in a flat rate USPS priority mailing box. Do not include any accessories/boxes that you want returned with the device. Our local USPS, UPS, and FedEx mail carriers have access to our secure locked drop off location. Sending devices signature required can create delay, but does offer an additional level of security during transit.
What Happens on Arrival?
We will process your device within one business day of arrival at iPad Rehab. You will receive an email with a "Hey we received it" message. If there is any missing information or question at intake, we will contact you by email on your ticket. The condition of your device will be recorded and your screen, housing, and logic board will be labeled and boxed. For law enforcement cases, we will capture a chain of custody with photos and store the device in a dedicated safe. Please do not send accessories, special boxes, or extras--these are difficult to keep with the device as it moves in secure containers through our system. Expect that anything extra sent with your device will not be returned. Devices mailed in are assumed to be an approval of the quote received.
RUSH SERVICE OPTION = GET STARTED RIGHT AWAY. RUSH service is a $200 non-refundable rush fee.
The rush fee is simply a charge to jump the queue and have your device looked at right away. Rush fee does not make your device 'more likely to be recovered' Rush is simply a 'get started now' fee and is independent of your data recovery service. Because most cases are recovered at the first session under the microscope, most of our rush cases will get recovered within a few days of being looked at. However, if your RUSH case is not recoverable or is a difficult problem that is not solved in the initial repair session then the rush fee is not refunded. Rush fee is just buying a front of the line pass. Rush puts you in the "on deck" position in the queue. Some RUSH cases are recovered after months or years of waiting. WE CANNOT GUARANTEE A QUICK TURNAROUND ON ANY JOB.
Standard queue can vary in length. During data high season it may take 6-8 weeks for your device to make it to the front of the queue, other times it may only be three or four weeks. Most devices (80%) are recovered on the first session under the microscope. If yours is not recovered when it first comes up for repair, then the technician will continue to circle back to your device indefinitely until either 1--We make a breakthrough to solve the case and it is recovered. 2--The technician discovers a data dealbreaker and deems the device unrecoverable.
Not unless there is some news. To keep our technicians focused on doing their work under the microscope, you will only hear from the technician if there is a problem and they need information, or if the device is recovered, or if the device is deemed not recoverable. At any other point in time after your device comes up for repair, your update is "we are trying to figure out how to get your device to boot, we are grouping it with others that have similar physical or electrical presentations and history. We will continue to do everything we can to figure it out, but we can't predict whether or not, or when, we will be able solve your case."
Cancellation is no problem as long as your device hasn't been disassembled and received time under the microscope. If yours was mailed in after receiving a quote, and the device has received an investment of repair time and chip cost, then we will assess a cancellation fee to cover the hourly labor and chip costs that have gone into the device. You chose iPad Rehab Microsoldering because we are passionate about data recovery and leave no stone unturned for our data recovery cases. This means that we often will continue to work on difficult cases long after it stops making business sense to do so. Be aware that it is not uncommon for a difficult recovery to receive dozens of hours of technician time and significant chip costs. The cancellation fee is always capped at the same price as your estimate for successful recovery. In addition to the cancellation fee, any recovery that is not successful that you want returned to you is subject to our safe reassembly plus shipping and handling fee, currently $30 for US domestic cases. You can sometimes avoid a cancellation fee by asking for a final look at your device to see if it can be deemed not recoverable. If there is no reasonable hope for recovery and you would prefer not to wait, we may deem your device not recoverable with today's technology which allows you to withdraw from an in progress repair without a cancellation fee.
"No Fix" Options: If we deem your device not recoverable with today's technology then you can simply opt to have us recycle what is left of your device and you owe us nothing for the time and materials that went into your device. We will remove the device from your iCloud account in accordance with our recycling policy. We may use the logic board for training or parts. After a device is deemed No Fix or not recoverable, we end our no fee investment of time and energy into the device. If you'd prefer us not to recycle the dead device, and you'd like us to put time into processing the device for return to you, we will send an invoice for safe reassembly and return shipping (~$30 domestic, $60 international) and you will receive a tracking number once paid and the device will ship home.
Once we get your phone to boot we will send you an email about your recovery and an invoice for Successful Data as soon as we have a path to data. We will wait for payment of the invoice to continue with data extraction and parsing.
We offer three levels of data extraction for iPhones. You may choose an iTunes back up only, pictures and videos only , or custom data based on your specific needs. The amount of data recovered will affect the cost of the service due to the larger sized drive needed and labor time involved. We will copy your data to a usb storage device (additional charges may apply for larger size external storage devices). We will deliver your data on usb storage and we will also return your phone. For some devices iCloud backup may be an option. For many cases, the phone will have at least some function after recovery, although we don't guarantee function of the device. All devices will be recycled unless you request it to be returned. Return fee for devices which includes safe reassembly and return shipping (~$30 domestic, $60 international).
We put our heart and soul into every recovery. We expect payment for all successful data recoveries. If you do not pay for your data recovery after we send your invoice, we will assess $25 late fees at each 30 day interval. We will deploy a collections process to pursue you relentlessly until payment is received. If you are a cell phone repair shop that is sending a data recovery job in on behalf of your customer--then it is your responsibility to collect payment from your customer. From our perspective, YOU are our customer and we will expect payment from you regardless of what happens with your customer.
We reserve the right to alter or change these policies at any time.
