How to Get Data from a Samsung Phone that Won't Stay On
.jpg)
How to Recover Data from a Failing Samsung Phone: 5 Key Tips
If you've got a Samsung phone that won't stay on long enough to back up your important data, don't panic just yet. Before resorting to complex chip migrations or micro-surgery, there are a few practical steps you can try to extract your data. These methods can be surprisingly effective for reviving your phone long enough to secure those crucial files.
These simple tips can make a big difference when trying to recover data from a failing Samsung phone. If you're unsure about performing any of these steps yourself, consider reaching out to a professional repair service for assistance.
Watch our corresponding YouTube video here.
Tip 1: Reduce Screen Brightness to Save Power
One of the main reasons a phone may power off unexpectedly is because the battery can no longer provide enough current to keep up with energy demands. A simple but effective trick is to reduce the screen brightness. Lowering the brightness minimizes the battery drain, giving your device a better chance of staying powered long enough for a backup.
I recommend turning the brightness all the way down. You might even consider working in a dark room to make it easier on your eyes while you handle the backup. This method alone has saved many phones long enough to extract data.
Tip 2: Make Incremental Backups Using an OTG Cable
When time is of the essence, trying to complete a full device backup may not be practical. Instead, opt for smaller, incremental backups. Using a USB drive and an OTG (On-The-Go) cable, you can back up only the most critical files like contacts, messages, or photos.
To do this, plug the USB drive into the OTG cable, connect it to your phone, and navigate to the backup option under storage settings. Select "Custom" to back up smaller portions of data. Even if the phone shuts off again, you can merge these smaller backups later, thanks to Samsung’s ability to combine multiple backups using Smart Switch.
Tip 3: Use Heat or Cool the Device
If your phone’s issue is related to poor chip contact on the logic board, applying heat or cold may temporarily improve performance. A quick cool down in the freezer or placing the device on a fan can stabilize the phone just long enough to pull out essential files.
In one case, I used a fan and managed to recover about 2,000 out of 24,000 photos before having to perform a more advanced procedure. The same idea applies with heat: using a heat mat to slightly expand the metal can sometimes make all the difference in retrieving your data.
Tip 4: Backup to Different Locations
If your phone still has an SD card slot, using that for a backup is faster than connecting to a computer. You can also consider Bluetooth data transfers, which can be surprisingly efficient for contacts.
To share via Bluetooth, export your contacts as a VCF file and send it to another phone. It's faster than pulling an entire backup and can work when other methods fail.
Tip 5: Try a New Battery
If you’re comfortable working with phone hardware, a new battery might buy you enough time to get your data. Simply opening the back of the phone and manually connecting a fully charged battery (without fully installing it) could give the device the extra juice it needs to stay on.
This step is relatively straightforward, and even though it's not a permanent fix, it might save your data before needing professional help.
When All Else Fails: Advanced Chip Transfer
If none of these methods work, your phone may require professional intervention. If the problem isn't with the CPU or the storage chip (UFS chip), a skilled technician can transfer those chips to a working receiver board to recover your data.
The process involves carefully removing the RAM, CPU, and storage IC from your old board, reballing them, and attaching them to a new board. Once complete, the phone should power up long enough to complete a full backup using Smart Switch.
If you need help with a data recovery let us know how we can assist you. Fill out a quote request.
