iOS 18 and the Ongoing Battle with Parts Pairing
.jpg)
Could Today Be the Day Parts Pairing Is Finally Over?
With the release of the iOS 18 release candidate, there's hope that Apple will finally end parts pairing, a frustrating limitation that prevents users and repair shops from freely swapping parts between devices. But does iOS 18 deliver on this promise?
A Real-World Test: Greg's Flood Illuminator Problem
In today’s case, Greg's iPhone has a boot loop issue caused by a drop of water on his flood illuminator. The fix should be simple---disconnect the faulty part or replace it with a working one. But Apple’s restrictions complicate matters.
Before iOS 18, Greg had limited options:
  1. Apple’s Self-Service Repair Program**:** For $276, Greg can buy a new flood illuminator---bundled with a screen he doesn’t need.
    1. Removing the Part**:**Greg could boot his phone, but would lose critical features like Face ID, proximity sensing, and speaker functions.
    2. DIY Repair**:** A skilled technician could remove corrosion on the part using specialized tools, but that’s not viable for the average user.
Even with the potential of iOS 18, Greg’s hopes for a straightforward part swap seemed too good to be true.
Testing iOS 18: Did It Work?
Greg's phone, running iOS 17.5, rejected the replacement flood illuminator from another iPhone. So, the device was updated to iOS 18 to see if the restrictions would lift. Unfortunately, iOS 18 provided the same disappointing result---Face ID failed to work, and the dreaded "unknown part" message still appeared. Despite using a fully functioning OEM part, Greg’s phone couldn’t accept it.
The Bigger Problem: Parts Pairing Isn’t Going Away
This test reveals that, despite iOS 18 and growing support for right-to-repair legislation in states like Minnesota and New York, Apple’s parts pairing remains intact. The software update didn’t provide any relief for Greg’s issue.
What Can You Do?
This situation exemplifies why right-to-repair advocacy is crucial. It’s not right to spend $276 on a simple repair when a $15 part is readily available. If you live in a state with right-to-repair laws, file a complaint and push for stronger enforcement. The more voices demanding change, the harder it will be for companies to ignore.
In conclusion, iOS 18 may not have delivered the breakthrough we hoped for in the battle against parts pairing, but the fight isn’t over. Keep pushing for your right to repair! If you are interested in the companion YouTube Video click here.
