Unlocking Mystery: When Your iPhone Rejects the Correct Passcode
.jpg)
Ever had your iPhone reject the passcode you know is correct? That’s exactly what happened with Chris’s iPhone, and I think I’ve figured out why. Let me walk you through it because this could explain a common problem for a lot of people dealing with passcode issues, particularly after repair.
Chris's iPhone Problem: Correct Passcode, But It Doesn’t Work
Chris brought in his iPhone 11, and I was 100% sure of his passcode---911247. But when I entered the code, it was rejected. This kind of issue isn’t just frustrating---it can prevent access to important data. I had a theory, though, and it might shed light on why some people swear their iPhone is rejecting the correct passcode.
Understanding the iPhone 11 Logic Board
First, let’s talk about the iPhone 11’s logic board. It’s actually two layers:
The top layer contains all the data, including the CPU, NAND (storage), connectors, and everything that makes the phone function.
The bottom layer handles RF (radio frequency) functions like making/receiving calls, Wi-Fi, NFC (near-field communication), and Apple Pay.
When Chris’s phone arrived, it had a short circuit. So, I separated the top and bottom boards to see if the problem was on the top board (data-related) or the bottom board (RF functions).
The Issue with NFC: "NFC Divorce"
The short was on the bottom board, meaning the top board was fine. Normally, in this case, you’d think you could just extract data directly from the top board, right? Not so fast. When I connected a screen, battery, and charging port to the top board alone, the phone booted up, but it wouldn’t accept the passcode.
Why? The phone was trying to detect its paired NFC chip from the bottom board, but couldn’t. This is what I call the “NFC Divorce” issue. When the top board can’t find its original NFC chip (from the bottom board), it might accept the passcode, but hang on the last digit, leading to a "swipe up to recover" screen.
To recover the data, the phone needs to stay powered on for more than three minutes. But without a bottom board, which has the power button connection, the phone can’t stay on long enough.
Using a Donor Bottom Board
So, what’s the solution? I grabbed a known good bottom board from our parts bucket and created a hybrid with Chris’s top board. Normally, this setup would lead to a passcode hang on the last digit, followed by a swipe up to recover. Then the phone would unlock and recover data.
However, something unexpected happened. Instead of hanging on the last digit, the phone went straight to "iPhone unavailable" after just one incorrect passcode attempt. This was mind-blowing because it should give multiple chances to enter the code before locking out.
Fixing the Native Bottom Board
After some testing, I decided to fix Chris’s native bottom board. Once I did that and reassembled the phone, I entered the same passcode---911247---and guess what? It unlocked!
This was strange. It’s as if the NFC pairing between the top and bottom boards was causing the phone to reject the correct passcode when using a different bottom board.
The Bigger Picture: Why Does This Matter for Data Recovery?
For years, data recovery pros have been able to swap in any bottom board without worrying about the RF components since they don’t store user data. But Chris’s case suggests that there’s more going on---possibly something with the NAND, CPU, or even iOS version that’s preventing the phone from accepting the correct passcode when it detects an NFC mismatch.
Experiment Time: Swapping Boards
To dig deeper, I swapped in another phone’s top board (Justin’s) onto my known good bottom board. As expected, Justin’s phone hung on the last passcode digit before asking to swipe up and recover. After completing the NFC divorce process, Justin’s phone unlocked, as normal.
This confirmed that Chris’s board was behaving unusually---it wasn’t following the standard process of hanging on the last digit when paired with a different bottom board.
What Does This Mean for You?
If your phone is rejecting the correct passcode, it might be due to an internal disconnect between the top and bottom logic boards. This could happen due to water damage, a bad drop, or minor corrosion affecting the NFC circuitry.
If you’re seeing this problem, here’s what to do:
Do not keep entering the passcode---if your phone locks out with "iPhone unavailable," your chances of data recovery drop dramatically.
Try updating your iPhone’s software---this can force the NFC divorce process and allow the phone to stop looking for its native NFC chip.
In some cases, your phone might just need to update to recover. But if your phone can’t stay powered on long enough to update (more than three minutes), you might need to fix the bottom board to access your data.
Final Thoughts: Beware of "Bonking the Correct Code"
This case with Chris’s phone shows that what looks like a wrong passcode might actually be the correct one. It’s possible that some internal damage or NFC-related issue is causing the phone to reject the code. If you’re in this situation, don’t panic---just follow the steps outlined here to increase your chances of recovering your data.
To view our YouTube Video of this situation visit our YouTube channel.
If you’ve run into weird passcode rejection issues, drop a comment below---I’d love to hear about it!
